Hub One
- My Router
- Hub One
Hub One
16-04-2020 9:54 PM
I noticed last year that my laptop would keep disconnecting from my WiFi. I looked the problem up on the Internet and it seems that the 5ghz speed is causing the problem I've since switched it off which has fixed the problem but my router is now running on the slower speed, which is unfair considering I'm paying for a service I'm not really getting. Plusnet need to fix this.
Message 1 of 5
(270 Views)
4 REPLIES 4
Re: Hub One
17-04-2020 1:14 PM
@cyprus2 Welcome to the forum.
Plusnet are contacted to supply the speed over an Ethernet connection not wireless.
Before switching off the 5GHz band did you try separating the bands and trying each individually? If not give it a go. See https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Message 2 of 5
(192 Views)
Re: Hub One
21-04-2020 4:42 PM
Message 3 of 5
(143 Views)
Re: Hub One
21-04-2020 5:02 PM
Thank you so much, that seems to have fixed the problem.
Re: Hub One
21-04-2020 10:23 PM
Hi plusnet team
I thought baldrick1's seggestion had worked but it started disconnecting again today so I've made the changes you segested and I've rebooted the router I'll let you know if it happens again. Thanks for your help.
Message 5 of 5
(117 Views)
