Hub One
mantonis
Interested
Hub One
I have fibre with Hub One modem/router. I have three repeated problems which have gradually worsened:
1. The WIFI signal sometimes totally disappears and then some times re-appears after an indeterminate time
2. When I try to reconnect, I am often asked to enter the WIFI password which the router then does not recognise
3. The broadband download speed sometimes drops to a speed well below that of a poor ADSL connection (1-2MB). Ironically the upload speed is then often better. This also occurs with the PC close to the Hub One!
When the broadband is very slow I still get an excellent speed directly connected to the RJ45 port (well over 50MB) on the modem ie the problem is related to the router not the modem!
I have reset the router umpteen times and the problem still re-occurs.
When the speed is low (under 3MB it generally improves substantially after rebooting the Hub One (to over 50MB).
The problems are intermittent but occur now virtually daily!
I have tried a good quality repeater but this is just repeating the problems at its source ie the Hub One router!
Would it help if I connected a good quality stand alone WIFi router directly to the Hub One modem using an RJ45 cable and then disabled the Hub One WIFI? Does this require any specific settings?
I have a largish house with thick walls.
Any help would be appreciated as I am at wit's end!
3 REPLIES 3
bobpullen
Fixes: 231
Re: Hub One
Hi @mantonis,
Your problems sound very much related to this.
I have just pushed an update to your Hub One. You will need to power it off/back on at your side to apply it.
I'm hopeful that this will resolve most of your issues.
Fixes: 1,443
Re: Hub One
Moderators Note
This topic has been moved from  Fibre to My Router
mantonis
Interested
Re: Hub One
Bob,
Do you mean just disconnect the power and reconnect or should I reset the router?
I have done the former and will monitor the outcome during the next few days.
Mike
