Hub One with Airport Extreme Base Station
- My Router
- Hub One with Airport Extreme Base Station
22-02-2018 12:20 PM
I have just switched suppliers from Virgin to Plusnet. 3 weeks later and I now have a Hub One with a blue light allowing me to connect various devices over wifi. Speeds are incredibly slow compared with my (also live) Virgin network.
Previously I used an Airport Extreme Base Station used with Virgin which seem to give greater coverage and stability. Can I simply switch & connect via ethernet cable the Airport device to the Hub One? I have tried this but I get an Amber flashing light on the base station and the Airport Utility can't detect the device.
Any help advice really appreciated, I find hardware and networks baffling!
Re: Hub One with Airport Extreme Base Station
24-02-2018 10:00 AM
Are you connecting it correctly? The Ethernet cable should go between tha WAN port on the Airport Extreme and one of the yellow LAN sockets on the Hub One, not the Hub One WAN port.
24-02-2018 10:20 AM
Thanks so much for your reply. Yes, I am connecting the cable to the Base station WAN socket and the yellow Ethernet socket on the Hub One. Airport Utility is simply showing 'No configured Airport base stations have been found'
Any advice, much appreciated.
24-02-2018 10:28 AM
I have just completed a factory reset and this seems to have resolved. Will close this now. Many thanks.
- My Router
