Hub One s/ware updated on Oct 1st
- My Router
- Hub One s/ware updated on Oct 1st
02-10-2016 8:30 AM
I noticed yesterday my Hub One updated from the original Feb 16 s/ware to Software version 4.7.5.1.83.8.226 | Last updated 01/10/16.
Clicking my normal shortcut* this morning to access my speed settings this morning it now generates a different page:
ie IPv6 Configuration?
Hub IPv6 Gateway Address
Name: | dsldevice.lan |
Global Unicast Address: | Not available |
Link Local Address: | Not available |
Global Unicast prefix / length: | Not available |
*http://172.16.0.1/index.cgi?active_page=9141&request_id=1757633741&nav_clear=1
I'll persevere to find my original router landing page, or perhaps original page will return sometime soon.
Re: Hub One s/ware updated on Oct 1st
02-10-2016 10:01 AM - edited 02-10-2016 10:11 AM
It looks like the firmware update is being rolled out gradually.
3. Firmware version: | Software version 4.7.5.1.83.8.226 Last updated 29/09/16 |
However, I'm not seeing any indication that IPv6 is imminent.
IPv6 Hub Status: | Disabled |
IPv6 Network Status: | Disabled |
IPv6 will be disabled on your Plusnet Hub and Plusnet Broadband Network until supported by future services |
On the LAN (Home Network) side, I get this too:
It basically means that the DHCP server inside the router is not set up to issue IPv6 addresses to your devices.
02-10-2016 10:26 AM
Now discovered the landing page I want at:
http://172.16.0.1/index.cgi?active_page=9122&request_id=1757633741&nav_clear=1
02-10-2016 11:44 AM
- My Router
