Hub One s/ware updated on Oct 1st
Gel
Aspiring Champion
Fixes: 29
I noticed yesterday my Hub One updated from the original Feb 16 s/ware to  Software version 4.7.5.1.83.8.226 | Last updated 01/10/16.
Clicking my normal shortcut* this morning to access my speed settings this morning it now generates a different page:
ie IPv6 Configuration?Huh
Hub IPv6 Gateway Address
Global Unicast Address: Not available
Link Local Address: Not available
Global Unicast prefix / length: Not available
*http://172.16.0.1/index.cgi?active_page=9141&request_id=1757633741&nav_clear=1
I'll persevere to find my original router landing page, or perhaps original page will return sometime soon.
3 REPLIES 3
bobminors
Re: Hub One s/ware updated on Oct 1st
It looks like the firmware update is being rolled out gradually.
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 29/09/16
However, I'm not seeing any indication that IPv6 is imminent.
IPv6 Hub Status: Disabled
IPv6 Network Status: Disabled
IPv6 will be disabled on your Plusnet Hub and Plusnet Broadband Network until supported by future services
On the LAN (Home Network) side, I get this too:
It basically means that the DHCP server inside the router is not set up to issue IPv6 addresses to your devices.
Gel
Aspiring Champion
Fixes: 29
herojan
Does anybody what what changes were in this update?
