Hub One router hissing
- My Router
- Hub One router hissing
20-08-2018 12:04 AM
Re: Hub One router hissing
20-08-2018 11:09 AM
It's a very well known problem. Don't listen to advice regarding switching off the 5GHz wireless just ask for a replacement that's fit for purpose. THe manufacturer must be making the odd one that doesn't have this issue.
It just staggers me how long Plusnet have kept shipping these faulty routers, presumably they are just hoping that few will complain rather than dumping this tainted product.
20-08-2018 1:00 PM
Hi @Bhav, welcome to the Community Forums.
As @Baldrick1 has advised, it is a known issue with some Hub One's and you can turn off the 5GHz Wireless to stop the hissing.
I have sent you a replacement router however and it should be with you within the next few days, let us know if we can assist further.
20-08-2018 1:11 PM - edited 22-08-2018 10:26 AM
@Bhav, would you be able to send the faulty device back to me here at the office?
FAO: Bob Pullen
The Balance
2 Pinfold Street
Sheffield
S1 2GU
I have a collection of these that I'm looking to send over to the vendor for analysis. I'll happily apply some credit to your account to cover the cost of postage/your efforts.
AFAIK, the last time this was looked into, the componentry was found to be operating within tolerance thresholds.
20-08-2018 3:52 PM
Bob,
I have looked up compentry and still don't know what it is that's within tolerance.
The thing I have noticed is the string of complaints that has now gone on for months on this issue. There's obviously something such as a wound component that isn't encapsulated causing this issue.
20-08-2018 8:38 PM
@bobpullen Could it perhaps be componentry, if so its a word I've not seen used before. What are the acceptable noise levels for a router? There are many complaints about this noise problem and no apparent solution yet.
22-08-2018 10:29 AM - edited 22-08-2018 10:30 AM
Yes, apologies. I've edited my post. I suspect it's some of the capacitors responsible for the noise.
I don't know the exact thresholds, but as mentioned previously, I plan on opening a new case with the vendor for investigation regardless, so hopefully some good will come of that.
22-08-2018 10:03 PM
@bobpullen wrote:. I suspect it's some of the capacitors responsible
Ah, this sort of thing
https://product.tdk.com/en/contact/faq/31_singing_capacitors_piezoelectric_effect.pdf
