Hub One replacement for Openreach modem / Netgear router combo
- My Router
- Re: Hub One replacement for Openreach modem / Netg...
03-11-2019 8:00 AM
Just replaced a Openreach modem / Netgear router combo with a +Net Hub one. Nice to have the extra WiFi band and a free plug socket but it doesn’t attach to the wall and wonder if I’ve done the right thing?
Re: Hub One replacement for Openreach modem / Netgear router combo
03-11-2019 10:47 AM - edited 03-11-2019 10:48 AM
No, this is correct.
The Plusnet Hub One is designed to be free standing, and not mounted to the wall; like the Modems were.
Make sure it’s high up (not on the floor) and away from obstruction for the best signal.
03-11-2019 10:57 AM
Your problem can be solved for £7.25. See https://www.ebay.co.uk/itm/Plusnet-Wall-Bracket-Plusnet-Wall-Mount-W-Fixings-/152659822199
03-11-2019 7:22 PM
Thanks for your post @catshill1.
I'm afraid that it's not wall mountable and we unfortunately don't supply a version that is for VDSL.
I'd have to agree with @Baldrick1's suggestion regarding picking up a wall bracket from an online retailer.
Please let us know if you need any further assistance.
04-11-2019 7:27 AM
I am thinking about reverting to the Oopenreach model / Netgear WNR1000 combo as although it only has one wifi band it coverage is noticeably better than the Hub One.
- My Router
