Hub One remote access to configure and manage router
nightowl1
Hi All,
Could anyone provide some guidance as to how I can access my Hub One router remotely as its installed in my rented flat?
I'm guessing I would need to open a url like http://<WAN IP of router>/PORT
Thanks Andy
3 REPLIES 3
Fixes: 413
Re: Hub One remote access to configure and manage router
This has been asked several times before and the conclusion has been that it's not possible with the Plusnet offering. An example:  https://community.plus.net/t5/My-Router/Plusnet-One-Hub-Remote-Access/td-p/1528421
nightowl1
Many thank for your quick reply, much appreciated!
japiewie
You can but not direct.Get a Pi Zero W. Install SoftEther VPN. Set de correct portforward on the router.
PiZero W uses so littlepower you can feed it from de router's usb 🙂
