Hub One rebotting 2-3 times a day. Boot reason: watchdog reset (cause: 0x3)
- My Router
- Re: Hub One rebotting 2-3 times a day. Boot reason...
12-08-2019 8:49 PM
My router is restarting very frequently, it didn't do this when I first got it so I'm not sure what happened. Internet connection is fast and working well when the router behaves. I thought this was related to heavy file transfer and streaming over my network, but it seems to happen when I'm not doing very much at all.
From what I've read on here it looks like a faulty router?
Any help appreciated.
Event log shows the following cycle:
20:30:42, 12 Aug. | ( 32.520000) System up, firmware version: 4.7.5.1.83.8.263 |
20:30:27, 12 Aug. | ( 18.080000) System start |
20:30:27, 12 Aug. | ( 18.080000) Boot reason: watchdog reset (cause: 0x3) |
Re: Hub One rebotting 2-3 times a day. Boot reason: watchdog reset (cause: 0x3)
13-08-2019 9:33 AM
Sorry to hear you're having connection issues. I've tested your circuit and can't find any issues that would cause this to happen.
Can you run through our troubleshooting guides here.
If that doesn't help, the next thing would be to rule your internal wiring out by plugging the connection into your test socket (which is under the faceplate of your master socket) and seeing if the drops stop.
This rules out your internal wiring, face plates and extension sockets as being the cause of these drops.
How to locate the test socket and set your connection into it can be found here
If the problem still persists, please can you raise a fault here
Kind Regards,
MoR
14-08-2019 3:10 PM
fwiw, it could be a failing power adapter.
How old is it?
14-08-2019 9:21 PM
Thanks for your response. As I stipulated in my original post I am not having any internet connection issues at all, so I can't imagine plugging into the test socket is going to make any difference. The router is power cycling by itself.
14-08-2019 9:25 PM
The router and power supply is around 8 months old. I feel like it started happening fairly soon after I set the 2.4Ghz and 5Ghz wifi to seperate SSID's. My chromecast refuses to work if had these combined, despite the fact that it was working fine for the first 2 months. It seems like maybe a firmware update may have been the trigger, but it's hard to say.
15-08-2019 10:56 AM - edited 15-08-2019 10:56 AM
Thanks for getting back to us @paulwillis82
I'm sorry to see how this has been handled, I've done some digging into the watchdog reset error code you're seeing in your router logs and I've came across and have had a read of this thread.
What devices do you have connected to the router, in particular do you have a NAS device? Although either way it seems like the answer is to replace the router so I've got a new one ordered which should land within the next few days.
I hope this helps.
15-08-2019 9:06 PM
I hope this helps.
Thank you Gandalf (words I never thought I would be typing). I really appreciate you looking into this for me and sending a replacement. It is a shame that some other members of your team didn't read my post properly!
I don't have a NAS attached, only a Philips smart lighting hub connected via ethernet and a PC which is usually switched off.
Thanks again
16-08-2019 10:08 AM
Always a first time for everything I also go by Anoush if it doesn't feel right to write Gandalf.
No problem, let us know how it goes once you've received it.
- My Router
