Hub One question - port forwarding - only allow a specific ip address
vincentvega
Long time customer. Just received a Hub One. Ripped out the old modem and my Netgear "N" router and just have the Hub One connected now which is a little less cluttered... Signal strength and speed around the house much much better than my old Netgear, so pleased with that.
I have configured port forwarding for my PC at home... I regularly RDP to it from work. Tested RDP and works fine.
However, really I want to limit the inbound RDP connections to allow only RDP connections from my office static ip address.
This was a simple task on the Netgear - can't see anywhere to do this on the Hub One? Looks like a port is either "open to everyone" or "closed" - is it possible at all or will I have to live with this?
2 REPLIES 2
bobpullen
Fixes: 291
Re: Hub One question - port forwarding - only allow a specific ip address
I don't think it's possible. You might be able to achieve similar by setting up an inbound TCP rule using the Windows Firewall though.
https://security.stackexchange.com/questions/34709/enable-rdp-for-internal-network-only
vincentvega
Yes that was my next port of call, and I have set it up that way... works fine, thankyou.
