Hub One poor wifi lookinf at options
- My Router
- Hub One poor wifi lookinf at options
04-02-2017 8:51 PM
Hi guys (& girls) we should be getting fibre connected next week & as such we have received the one hub. I have connected it then separated the 2.4ghz from 5ghz wi-fi but the wi-fi signal is terrible in comparison to my old Netgear. I've tried changing the channels but the signal is still rubbish (moving room can cause a signal drop) The Netgear is not VDSL compatible so we are wondering if we should just buy a cheap VDSL modem & use the Netgear of would we be better off buying another AIO modem/router? our speed should be around 45-50mbps
I looked at http://www.netgear.co.uk/home/products/networking/dsl-modems-routers/DM200.aspx?cid=wmt_netgear_orga...
rob
Re: Hub One poor wifi lookinf at options
04-02-2017 10:36 PM
One option is to turn DHCP OFF on the netgear, and turn WiFI OFF on the Hub1.
Plug the netgear into a LAN port on the Hub1.
Connect to wifi on the Netgear and it should get an IP to the device form the Hub1 which is now just acting as a VDSL modem and Hub. Can plug lan devices into either too!
- My Router
