Hub One not updating firmware
siegerson
I have the 5Ghz but on a hub one that has not been connected in a while.
Hub showing Software version 4.7.5.1.83.8.263 Last updated Unknown
Been connected for a couple weeks now.
8 REPLIES 8
bobpullen
Fixes: 330
Re: Hub One not updating firmware
Try a factory reset by inserting somethign into the pinhole at the rear of the device until the status light flashes green. I've made some adjustments this side that should hopefully see the latest firmware pushed within a few days of the reset.
siegerson
Thanks.
PM sent with serial number
siegerson
Nothing changed as of yet, still not updating
bobpullen
Fixes: 330
@siegerson - there have been several failed attempts to update your firmware. Reason for failure would seem to be because your hub lost contact with the management platform shortly after it was reset back on the 17th.
Are you restoring a backed up configuration after factory resetting? If so, it's likely overwriting the management address with 'bad' info. You will need to avoid restoring from a prior back-up to prevent this happening.
siegerson
Yes I was restoring backup, will try another reset tonight without restoring back up.
Thanks again Smiley
SammyM
Fixes: 101
No problem @siegerson, let us know how you get on.
 Sammy M - Sheffield Team
siegerson
Update complete, thanks 👌
adamwalker
Fixes: 223
Cheers for letting us know @siegerson and please shout up if there's anything else we can help with.
 Adam Walker
