Hub One losing internet connection on 5Ghz WiFi only
- My Router
- Hub One losing internet connection on 5Ghz WiFi on...
5 GHz connection dropping out
01-09-2019 1:50 PM
I am experiencing the similar fault as many on here where my 5GHz wifi signal drops out daily and disconnects iOS connected items and requires a Router reboot to re-establish the connection. I did get a new Router from Plusnet last week when I upgraded to unlimited Fibre Plus but the issue has continued.
I have read on here about splitting the 2.4GHz and 5GHz signals but that seems to also have limited success. Also there is a post that mentions a newer Firmware that has helped with this issue. This may be a Beta testing version?. I am currently on Firmware rev: 4.7.5.1.83.8.263 with no last update date. Also was wondering how you upgrade the Router firmware?
Re: 5 GHz connection dropping out
01-09-2019 2:21 PM
01-09-2019 2:27 PM - edited 01-09-2019 2:29 PM
Thanks for the update,
does anyone know if Plusnet are still looking at this issue or is there another fix that I have not found yet?
Re: Hub One losing internet connection on 5Ghz WiFi only
01-09-2019 2:50 PM
01-09-2019 5:16 PM
Unhelpful post removed.
Forum Moderator and Customer
02-09-2019 9:57 AM
Thanks for getting in touch @cruickc2
I'm sorry to see you're experiencing problems with your 5GHz wireless frequency dropping out. We are still investigating this and I'm afraid I'm unable to advise when this will be resolved.
What may help our investigation is if you could complete the below questionnaire that our products team have provided. This will hopefully allow us to replicate the problem in a lab environment.
1. Exactly how does the problem masquerade itself, what are the symptoms?
2. When did the problem start?
3. What firmware version are you running and when was it last updated?
4. What devices do you have on their network and how are they connected, e.g. wired or wireless?
5. How is your network configured i.e. any Powerline adapters, additional switches, attached storage or or wi-fi access points in use?
6. What devices does the problem affect and what software/firmware versions are they running (if known). This will help us try and replicate the issue in a lab environment.
7. Are the 2.4GHz/5GHz radios separated or merged (they're merged by default). If separated, which radio is affected (or is it both)?
8. Has the customer tried factory resetting? (If you've not, please try this)
9. Would you be willing to downgrade firmware if we need to in order to help diagnose the issue. Bear in mind this will wipe all of the settings back to factory defaults, and we may need to upgrade/downgrade a second time to further prove that it's the firmware that's the cause of the issue.
10. Would you be willing to facilitate a home visit so that hardware engineers can carry out further diagnosis of the problem? (note that any visit would be to capture further wi-fi diagnostics, and not to necessarily 'fix' anything).
Finally as a more immediate step it may be worth changing the wireless channel on the 5GHz frequency itself as I've heard from at least one person around these parts that appears to improve the stability.
02-09-2019 10:27 AM
I have the same issue;
All wireless connections loose access, even to the extreme of you cannot see the SSID in the available networks list.
Approx 1 month ago, but am new customer.
Software version 4.7.5.1.83.8.263 | Last updated 28/07/19
Ethernet;
Mac pro, Nas drive, Ripe Atlas, Dell R710 server
Wifi;
4x iPhones, 1x ipad, 2x kindles, 1x HP printer, 2x HP laptops, wifi connected thermostat & Roku
NTE-> Plus net router -> switch -> ethernet devices as per question 4, (wifi devices connected to plus net router AP)
All wifi devices
Merged
Yes, paper clip method
Yes
Yes.
02-09-2019 1:11 PM
Two threads merged.
02-09-2019 2:40 PM
02-09-2019 4:35 PM
IMac and IPhones still indicate a Wi-Fi connection but no Internet pages load up and when you investigate the Wi-Fi connection on the IMac it see’s my Wi-Fi network but states its searching for a Network. Any equipment connected to the 2.4Ghz signal still work and access the Internet
Approx. 9 to 12 months ago, not 100% sure could even be longer
4.7.5.1.83.8.263-This is a new Router you sent out last week and doesn’t state when last updated. Unsure what version my old Router was but that was around 3 years old and had the same issue
Wired- Philips HUE Bridge, SAMSUNG SMART Things Bridge, Tado- Bridge, SONOS Boost, Xbox One.
Wireless- IMac, 3 x Ipads, 4 x IPhones, 3 x IWatches, Kodak Verrite 55 printer, Apple TV, Amazon Fire stick, 3 off Panasonic Smart TV’s, SKY Q
5. How is your network configured i.e. any Powerline adapters, additional switches, attached storage or Wi-Fi access points in use?
Router is connected straight into ADSL ext in Master socket, also one additional NETGEAR GS205-100UKS 5 Port Gigabit Ethernet desktop switch connected to the Router to give 4 off extra connections
It appears to be only the IMac and IPhones, unsure if the Panasonic TV’s are dropping out as haven’t checked these (IMac is running Mojave version 10.14.6, IPhones latest version of IOS)
Merged
Yes
Yes
Yes
10-09-2019 7:51 PM
Any update on this from PN?
I have been a LONG sufferer of this issue across 3 replacement routers.
10-09-2019 8:45 PM
Not as far as I know, no. About 3 weeks ago my 5GHz spontaneiously began working again! It lasted a few days, maybe a week, then dropped out again and continued to not work as it had since March. I finally followed the example of some others on this or one of the parallel topics here on the same issue and bought myself a BT Business Smart Hub on eBay. They're under £30, and once you've got it set up (there's another thread here with excellent step-by-step instructions) you can chuck your PN Hub1 along with its useless firmware update! I am seriously disappointed in Plusnet's failure to assist us with this in any meaningful way, or to keep us appraised of what (if anything) they are doing. I think they subscribe to the Boris Johnson School of Stakeholder Rejection. It's only laziness that has stopped me moving to the opposition, and that won't last forever.
10-09-2019 8:58 PM
Am in full agreement with everything you have said. I have been with them for years and various house moves, and this was the first year I almost left over a billing issue of over payment even while suffering this WiFi craic.
Will have to pick up something in the interim until the contract ends as running 2.4Ghz only is a bit of a pain
13-09-2019 6:13 PM
I wish I found this thread earlier. I’m also having 5g completely disconnect. 2.4g is fine. Plusnet did send me a replacement router but the same issue occurs. All my 5g devices (mostly google home and chromecasts) are dumped from the network and cannot reconnect until the router is rebooted.
I’ve been a customer for around 10 years but this is a deal breaker for me. With this and the over billing issue I’m losing faith. Reading this thread there is no end in sight so can I exit my contract early as a result of this?
13-09-2019 7:26 PM
- My Router
