Hub One info wanted
- My Router
- Hub One info wanted
Hub One info wanted
13-05-2016 11:05 AM
is there anywhere a manual for the Hub one... set up AOK as normal but doesn't work on USB to printer or USB to external HDD i would like to see some serious tech info on this. also on how many wifi units it can support... the sales guy told me it was an infinite number! my old TG582 would only support 3 wifi connections.
Re: Hub One info wanted
13-05-2016 11:22 AM - edited 13-05-2016 11:23 AM
you can't use a printer with the USB port on the hub one.
i've got a usb drive working with it ok.
number of wifi devices at least 16.
it's the same as a home hub 5 so any info on that will apply.
some info here http://www.plus.net/support/broadband/hardware/hub-one-user-guide.shtml
13-05-2016 11:35 AM
23-05-2016 9:55 PM
You'd hope so, but we're experiencing lots of lag and dropouts once we go above 5 devices. Have raised a ticket but struggling to get past the "have you turned it off and on again" step
24-05-2016 5:32 AM
not experienced the symptoms you're seeing. is it any particular device that's suffering?
24-05-2016 7:26 AM
Have you looked at wifi channel congestion / overlap? See inSIDDer - a software tool which displays the use of the wifi spectrum in your locality. V3 is free.
