Hub One info wanted
thistlecottage
Hub One info wanted
is there anywhere a manual for the Hub one...   set up AOK   as normal but  doesn't work on USB to printer   or USB  to external HDD     i would like to see some serious tech info on this.   also on how many wifi  units it can support... the sales  guy told me it was an infinite number!    my old TG582   would only support 3  wifi connections.
5 REPLIES 5
Fixes: 819
Re: Hub One info wanted
you can't use a printer with the USB port on the hub one.
i've got a usb drive working with it ok.
number of wifi devices at least 16.
it's the same as a home hub 5 so any info on that will apply.
some info here http://www.plus.net/support/broadband/hardware/hub-one-user-guide.shtml
Browni
Aspiring Hero
Fixes: 49
From the help within the hub:
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
matthews
You'd hope so, but we're experiencing lots of lag and dropouts once we go above 5 devices. Have raised a ticket but struggling to get past the "have you turned it off and on again" step Sad
Fixes: 819
interesting that was from my personal experience - 4 x phone, laptop, tablet which are pretty constantly on plus other things like game consoles, printer that are often on.
not experienced the symptoms you're seeing. is it any particular device that's suffering?
Fixes: 35
Have you looked at wifi channel congestion / overlap?  See inSIDDer - a software tool which displays the use of the wifi spectrum in your locality.  V3 is free.
