Hub One horrendous wifi performance for all devices - wired fine
- My Router
- Hub One horrendous wifi performance for all device...
10-01-2020 1:26 PM
Still having some horrendous wifi issues, I can be sat within 5 foot of the hubone and my iphone will still spinny wheel of doom til I drop the wifi and use my 4G data..
Wired performance is spot on..
Re: Hub One horrendous wifi performance for all devices - wired fine
10-01-2020 3:16 PM
Try splitting the 2.4 and 5GHz bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Try each band in turn and use the best.
10-01-2020 3:23 PM
That was one of the first things I did when I got the hub one. Doesn't matter if 5ghz is off, performance is atrocious.
10-01-2020 4:54 PM
i have the same problem with any Apple product. All my android devices work fine...
10-01-2020 5:20 PM
In my case, Android, Kindle, and Win 10 Laptops all have the same problem..
10-01-2020 6:21 PM
The PlusNet router is basic (a re-badged BT HH5) as per PlusNet's status as a "value" not premium brand.
You could consider getting a BT HH6 or the even newer SmartHub2 from eBay for aroung £30.
- My Router
