Hub One fixed IP for DHCP client
jason68
Interested
Having moved from the Hub Zero to the Hub One I am missing my 'secret' advanced options, but I have found one that isn't obvious..
To give a DHCP client a fixed IP do the following:
  1. go to the advanced settings
  2. go to Home Network
  3. find your device (it obviously must be connected, matching its current IP if it doesn't have a name)
  4. click on the Name/MAC/IP link
  5. you can now choose - Always Use This IP option, and even change the default IP
I hope that this is useful. It's not everything that is missing, but the one thing I wanted (with the exception of using OpenDNS)
J
