Having moved from the Hub Zero to the Hub One I am missing my 'secret' advanced options, but I have found one that isn't obvious..
To give a DHCP client a fixed IP do the following:
- go to the advanced settings
- go to Home Network
- find your device (it obviously must be connected, matching its current IP if it doesn't have a name)
- click on the Name/MAC/IP link
- you can now choose - Always Use This IP option, and even change the default IP
I hope that this is useful. It's not everything that is missing, but the one thing I wanted (with the exception of using OpenDNS)
J
