Hub One file sharing
- My Router
- Hub One file sharing
28-05-2019 4:54 PM
Re: Hub One file sharing
29-05-2019 3:21 AM
Moderator's Note(s)
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
29-05-2019 7:25 AM
29-05-2019 8:51 AM
Can it be updated to SMB2 as apparently there is a security issue with SMB1?
29-05-2019 8:53 AM
The simple answer to that @Neil17 is no.
29-05-2019 7:34 PM
Depending on budget and how much you want the sharing I would recommend going down the Network Attached Storage (NAS) route.
I've tried a few different makes but now I would recommend a Synology over the cheaper options.
What I particularly like about it (as well as the obvious shared file storage) is that it will make any printer with a USB connection shared (and able to be printed to by Apple devices).
The Synology is also capable of lots of other clever stuff which may or may not be of use.
