Hub One drops connection with smart dvr after 15mins
knellerhall
Interested
Recently moved to PN from BT. Was using HH5 (type B) with a home network setup to access music, pics etc from a Panasonic DVR. Hub was connected to PC by ethernet and DVR to hub by wireless. All worked fine.
Swopped the hubs, changed nothing else, and now, 15mins after logging the dvr on to the network it loses connection to the hub and I have to reconnect, 15mins later, same again. Time varies a little as it always disconnects between music tracks, or between pictures. This makes me wonder if there is some sort of time out request or something in the hub.
However if I put the BT one back (without internet connected) - no problem. In fact I currently have the BT hub just set up to connect between PC & DVR.
I assume I could use the BT hub only or just carry on as I have it now, but anyone any idea why this is happening?
2 REPLIES 2
mikelahey
Fixes: 12
Re: Hub One drops connection with smart dvr after 15mins
You could swap the Hub One out for the BT Homehub 5B and use it for Internet and LAN / WiFi
see posts 1 & 7 on this thread: https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234
The Plusnet Hub One is a re-branded BT Homehub 5A  anyway.
knellerhall
Interested
Thanks, bit of a 'plug & play' type of guy but I have got the Bt hub working as you suggested!
