Hub One buzzing/hissing noise.
FIXED- Subscribe to RSS Feed
- My Router
- Hub One buzzing/hissing noise.
Re: Hub One buzzing/hissing noise.
11-09-2018 12:56 PM
Hello,
I have exactly the same issue could you send replacement router for me please.
11-09-2018 1:36 PM
I've received it, installed it, two weeks of silence then same problem. 😕
Florian
11-09-2018 5:28 PM
Hi @reggie83 I'm sorry to hear that you're experiencing the same problem. I've sent you a replacement to try and it'll be with you within 3-5 working days.
@Florian, I'm sorry to hear that this problem has returned with your new router. Please can you try a factory reset via the pinhole on the back - please let us know if the issue persists after this.
18-09-2018 2:08 PM
Sorry for the reply but iv never really done forums and the like. Iv just come across to Plusnet from Sky, roughly 3 weeks of working fine. I noticed a wierd noise and its only having turned everything else off i have put it down to the router.
Its evident when i go to download, stream etc and the router is working.
You should be able to tell when it arrived, it was brand new. Iv done the resettting thing a few times now but its not fixed it.
Appreciate some help.
Ashley
18-09-2018 7:53 PM
Hi Ashley.
No worries, welcome to our community forums.
I've ordered a replacement now. Once you receive it could you return the old one as per these instructions so we can investigate further?
19-09-2018 1:35 PM
Hi
I have also noticed that over the last couple of months a static/fizzing kind of noise coming from my router, particularly when its actively transmitting video to my TV. I also feel the broadband wireless signal around my house isn't as good as it used to be. Can I get the router replaced too, please?
Phil.
19-09-2018 1:53 PM
I've tried everything. Nothing worked so far.
The router has to be in my room as it the only BT Socket available.
Are you planning to make an upgrade? Otherwise I will think about changing my internet provider
20-09-2018 12:13 PM
16-10-2018 11:29 AM
Hi
I am also experiencing those hissing/buzzing sound from the router.
Is it possible to have a replacement router sent please?
Thank you
16-10-2018 7:50 PM
Hi @ericwbriggs,
I've done that for you.
Once you've received the new one could you please follow the instructions here to return the old one for testing. Once sent back if you raise a ticket on your account here and attach a copy of the charges for the postage you paid we'll credit it back to your bill.
05-11-2018 9:44 PM
06-11-2018 1:45 PM - edited 06-11-2018 1:46 PM
Hi @rendermark,
I'm sorry that you're also experiencing this issue and for any inconvenience caused.
I've ordered you a new router now and it'll be with you within 3-5 working days. Once you've received the new router, please can you follow the instructions from @JOLO's post to send this to us for testing?
09-11-2018 8:46 PM
Hi Guys,
My Hub one is also suffering from this "white noise" while its under any load through the WiFi. it cripples 5ghz performance and halves 2.4ghz speed. Using Ethernet is perfect with no noise but not ideal for things like my FireTv or my phones. sounds to me like coil whine/cap whine. Is it possible to get a replacement as it's rendered the unit all but useless for anything but wired connections.
10-11-2018 7:57 PM
Hi @NotHarryPotter,
Thanks for your post.
I've ordered you a replacement router which should be with you within the next 5 working days.
Please pop the old one in the prepaid returns bag, so that we can check it out when it comes back to us.
Let us know how you get on and please don't hesitate to drop us another post if you need any further assistance.
18-11-2018 1:22 PM
regards
mark render
- My Router
