Hub One buzzing/hissing noise.
Markd123
Hi
I have just recently switched from BT fibre to Plusnet. Connection is excellent and speeds are also excellent, but I have noticed that my router is making a buzzing/hissing sound only when running on 5ghz. I have seen various  threads regarding this and it looks like I seem to be having the same issue as others.
Would it be possible that I have been sent one of the faulty routers and would I be able to get a replacement router sent out?
46 REPLIES 46
Fixes: 1,292
Re: Hub One buzzing/hissing noise.
Sorry to hear this.
I've processed an RMA for you now so you'll receive a new one within the next few days.
Let us know how it goes.
Markd123
Thanks for replying, I will reply with an update when the new hub arrives.
Fixes: 1,292
No problems. Fingers crossed the new one is better.
halfway69
Hi
I’m also having issues with a hissing sound coming from the router.
Is it possible to have a replacement router sent please?
Thanks.
deank
Fixes: 14
Hi @halfway69
I have RMA'd this for you, and another will be with you shortly.
 Dean R
 Plusnet Staff
Markd123
Hi @Gandalf
New hub received and tested and issues seems to be resolved. I will return the old one over the next few days, thanks again for the quick response and resolution.
deank
Fixes: 14
Hi @Markd123
Glad to hear everything is working for you again, please let us know should you have any further queries.
 Dean R
 Plusnet Staff
halfway69
Thanks all set up and working.
Do I need to send the old one back? If so how do I do this?
RandallFlagg
Fixes: 75
Hi @halfway69
Thanks for getting back in touch. I'm pleased to hear that the replacement router has solved the noise problem.
In this instance we wouldn't require you to return the previous router, so feel free to keep it as a spare or to dispose of it through any local recycling facility.
Best wishes,
Dave
Florian
Hello
I am also experiencing those hissing sound from the router.
Thank you
RandallFlagg
Fixes: 75
Hi @Florian
Thanks for letting us know - I've arranged for a replacement to be dispatched.
Let us know how you get on when it arrives.
Best wishes,
Dave
bobpullen
Fixes: 194
Guys, if people are encountering this issue, then I'd appreciate the devices are sent back to us at the office for evaluation, rather than blindly RMA'd.
I recognise this is an inconvenience as people will need to cover the cost of postage themselves, but I'd be happy to offer refunds/credit for those who make the effort.
FAO: Bob Pullen
Ref: CPE-44
The Balance
2 Pinfold Street
Sheffield
S1 2GU
Using the returns bag that comes with the replacement router will result in the device getting sent back to the fulfilment centre, which won't help towards identifying the underlying cause of the problems.
jsaz1001
Hi my router is making the exact same noise and have read that many other people have been having the same problems and that its a faulty router? Please could I also get a replacement? It's very loud. Thank you
Fixes: 1,292
Hi @jsaz1001
I've RMA'd your router now which means we'll send you a new one within the next few days.
Instead of using the returns bag could you post it back to us here at the office marking it to the attention of Bob Pullen, as above.
Let us know how it goes with your new router too.
