Hub One and VPN
- My Router
- Hub One and VPN
Hub One and VPN
14-02-2017 7:37 PM
Hi I have a VyperVPN account but can't seem to find a way to set access up to this in the hub one router settings as there is no way to either change DNS or input a username/password combination - am I missing something or is it just a very basic router?
Message 1 of 2
(816 Views)
1 REPLY 1
Re: Hub One and VPN
14-02-2017 7:44 PM
The Hub One is not on the list of supported routers for "VyprVPN for Routers"
You will need to use VyprVPN on your PC/MAC/phone if those devices are supported.
Or buy a VyprVPN supported router.
Message 2 of 2
(812 Views)
