Hub One and DVR
maurice1004
Hub One and DVR
Hi I have set up my plus net hub one router, everything seemed to be working fine until i tried to forward the ports for my CCTV DVR, the device is now showing up in attached devices therefore i cannot identify ip.
Has anyone ANY idea why this would be happening
Contacted support to be told it wasn't their remit
Help
5 REPLIES 5
bobminors
Re: Hub One and DVR
Is it a USB connection? If so, it doesn't have a separate IP because it's "part of" the Hub One itself.
maurice1004
Re: Hub One and DVR
thanks for the reply but it connected by ethernet, it worked fine with previous two routers without issue, so i am bit confused as to why it won't show up in attached devices
bobminors
Re: Hub One and DVR
Okay, on the Hub One, look at the Troubleshooting / Event Log tab and pull down the "Wire LAN" category. Does it say anything useful?
maurice1004
Re: Hub One and DVR
Not sure what this means
Time and date Message
18:40:23, 18 Oct. ( 9277.860000) Admin login successful by 192.168.1.65 on HTTP
18:18:54, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:53098-​>[132.245.226.50]:443 on ppp3)
18:18:53, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:53102-​>[132.245.226.50]:443 on ppp3)
18:18:19, 18 Oct. ath00: STA cc:20:e8:34:32:34 IEEE 802.11: Client disassociated
18:18:19, 18 Oct. ath00: STA b8:53:ac:10:b2:3e IEEE 802.11: Client disassociated
18:18:19, 18 Oct. ath00: STA 00:a6:c6:0e:dd:e8 IEEE 802.11: WiFi registration failed
18:17:38, 18 Oct. ( 7913.160000) Host Grainnes-​iPhone (MAC cc:20:e8:34:32:34) using IP 192.168.1.68 detected on interface ath10, port -​1
18:17:32, 18 Oct. ath10: STA cc:20:e8:34:32:34 IEEE 802.11: Client associated
18:15:47, 18 Oct. BLOCKED 1 more packets (because of First packet is Invalid)
18:15:45, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.64]:53096-​>[132.245.226.50]:443 on ppp3)
18:15:43, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:53093-​>[132.245.226.242]:443 on ppp3)
18:15:37, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:53088-​>[132.245.57.18]:443 on ppp3)
18:15:28, 18 Oct. ( 7783.160000) Host MauricesiPhone2 (MAC b8:53:ac:10:b2:3e) using IP 192.168.1.64 detected on interface ath10, port -​1
18:15:21, 18 Oct. ath10: STA b8:53:ac:10:b2:3e IEEE 802.11: Client associated
18:08:26, 18 Oct. ath10: STA 00:a6:c6:0e:dd:e9 IEEE 802.11: WiFi registration failed
18:04:48, 18 Oct. ( 7142.770000) Host MauricesiPhone2 (MAC b8:53:ac:10:b2:3e) using IP 192.168.1.64 detected on interface ath00, port -​1
18:04:41, 18 Oct. ath00: STA b8:53:ac:10:b2:3e IEEE 802.11: Client associated
17:58:06, 18 Oct. ( 6740.320000) Lease for IP 192.168.1.65 renewed by host Maurices-​Air (MAC 7c:d1:c3:df:4d:81). Lease duration: 1440 min
17:58:06, 18 Oct. ( 6740.320000) Device connected: Hostname: Maurices-​Air IP: 192.168.1.65 MAC: 7c:d1:c3:df:4d:81 Lease time: 1440 min. Link rate: 6.0 Mbps
17:58:06, 18 Oct. ( 6740.250000) Lease requested
17:58:04, 18 Oct. ath10: STA 7c:d1:c3:df:4d:81 IEEE 802.11: Client associated
17:57:59, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:57:57, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>104.82.93.89 on ppp3)
17:57:22, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:57:20, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.204.10 on ppp3)
17:57:19, 18 Oct. BLOCKED 5 more packets (because of ICMP replay)
17:57:17, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.204.10 on ppp3)
17:56:33, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>104.82.93.89 on ppp3)
17:56:30, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:56:30, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>104.82.93.89 on ppp3)
17:55:20, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>212.159.9.2 on ppp3)
17:55:18, 18 Oct. BLOCKED 8 more packets (because of ICMP replay)
17:55:14, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>104.82.93.89 on ppp3)
17:55:12, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:55:11, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>104.82.93.89 on ppp3)
17:55:06, 18 Oct. BLOCKED 2 more packets (because of ICMP replay)
17:55:05, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>31.13.90.2 on ppp3)
17:55:02, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:55:02, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>31.13.90.2 on ppp3)
17:54:59, 18 Oct. BLOCKED 4 more packets (because of ICMP replay)
17:54:59, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>17.248.144.90 on ppp3)
17:54:56, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>17.248.144.152 on ppp3)
17:54:53, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:54:51, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>172.217.23.40 on ppp3)
17:54:03, 18 Oct. ( 6498.030000) Device disconnected: Hostname: Maurices-​Air IP: 192.168.1.65 MAC: 7c:d1:c3:df:4d:81
17:53:59, 18 Oct. ath10: STA 7c:d1:c3:df:4d:81 IEEE 802.11: Client disassociated
17:48:35, 18 Oct. ( 6169.900000) Lease for IP 192.168.1.64 renewed by host MauricesiPhone2 (MAC b8:53:ac:10:b2:3e). Lease duration: 1440 min
17:48:35, 18 Oct. ( 6169.830000) Lease requested
17:48:35, 18 Oct. ath10: STA b8:53:ac:10:b2:3e IEEE 802.11: Client associated
17:46:23, 18 Oct. IN: BLOCK [16] Remote administration (TCP [163.172.168.251]:48762-​>[194.75.4.105]:8080 on ppp3)
17:38:27, 18 Oct. ( 5561.670000) Lease for IP 192.168.1.65 renewed by host Maurices-​Air (MAC 7c:d1:c3:df:4d:81). Lease duration: 1440 min
17:38:27, 18 Oct. ( 5561.670000) Device connected: Hostname: Maurices-​Air IP: 192.168.1.65 MAC: 7c:d1:c3:df:4d:81 Lease time: 1440 min. Link rate: 162.0 Mbps
17:38:27, 18 Oct. ( 5561.600000) Lease requested
17:38:25, 18 Oct. ath10: STA 7c:d1:c3:df:4d:81 IEEE 802.11: Client associated
17:37:19, 18 Oct. IN: BLOCK [16] Remote administration (TCP [74.63.246.42]:60300-​>[194.75.4.105]:80 on ppp3)
17:33:22, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.198.238 on ppp3)
17:33:19, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:33:19, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.198.238 on ppp3)
17:33:16, 18 Oct. BLOCKED 4 more packets (because of ICMP replay)
17:33:16, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.208.170 on ppp3)
17:31:25, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>172.217.23.38 on ppp3)
17:31:24, 18 Oct. BLOCKED 2 more packets (because of ICMP replay)
17:31:22, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>172.217.23.38 on ppp3)
17:31:20, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:31:19, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>212.159.9.2 on ppp3)
17:31:18, 18 Oct. BLOCKED 4 more packets (because of ICMP replay)
17:31:16, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>54.192.11.140 on ppp3)
17:30:57, 18 Oct. BLOCKED 2 more packets (because of ICMP replay)
17:30:55, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.208.162 on ppp3)
17:30:54, 18 Oct. BLOCKED 4 more packets (because of ICMP replay)
17:30:52, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.208.162 on ppp3)
17:30:51, 18 Oct. BLOCKED 6 more packets (because of ICMP replay)
17:30:49, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>216.58.210.34 on ppp3)
17:30:48, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:30:46, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>31.13.90.36 on ppp3)
17:30:45, 18 Oct. BLOCKED 3 more packets (because of ICMP replay)
17:30:43, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>31.13.90.36 on ppp3)
17:30:42, 18 Oct. BLOCKED 1 more packets (because of ICMP replay)
17:30:40, 18 Oct. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 194.75.4.105-​>31.13.90.36 on ppp3)
17:29:43, 18 Oct. ( 5038.020000) Device disconnected: Hostname: Maurices-​Air IP: 192.168.1.65 MAC: 7c:d1:c3:df:4d:81
17:29:40, 18 Oct. ath10: STA 7c:d1:c3:df:4d:81 IEEE 802.11: Client disassociated
17:22:06, 18 Oct. ( 4580.400000) CWMP: session completed successfully
17:22:06, 18 Oct. ( 4580.220000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
17:22:03, 18 Oct. ( 4578.010000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
17:22:03, 18 Oct. ( 4578.010000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
17:22:03, 18 Oct. ( 4577.770000) CWMP: Initializing transaction for event code 2 PERIODIC
17:10:06, 18 Oct. IN: BLOCK [16] Remote administration (TCP [216.243.31.2]:41369-​>[194.75.4.105]:443 on ppp3)
16:58:26, 18 Oct. ath10: STA 00:a6:c6:0e:dd:e9 IEEE 802.11: WiFi registration failed
16:54:48, 18 Oct. ( 2942.720000) Host Grainnes-​iPhone (MAC cc:20:e8:34:32:34) using IP 192.168.1.68 detected on interface ath00, port -​1
16:54:44, 18 Oct. ath00: STA cc:20:e8:34:32:34 IEEE 802.11: Client associated
16:54:44, 18 Oct. ath00: STA cc:20:e8:34:32:34 IEEE 802.11: Client disassociated
16:53:28, 18 Oct. ( 2862.720000) Host Grainnes-​iPhone (MAC cc:20:e8:34:32:34) using IP 192.168.1.68 detected on interface ath10, port -​1
16:53:20, 18 Oct. ath10: STA cc:20:e8:34:32:34 IEEE 802.11: Client associated
16:53:12, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.69]:49276-​>[104.103.149.144]:443 on ppp3)
16:52:28, 18 Oct. BLOCKED 1 more packets (because of First packet is Invalid)
16:52:28, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.68]:50910-​>[17.252.59.246]:443 on ppp3)
16:52:04, 18 Oct. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.69]:49208-​>[104.103.128.139]:443 on ppp3)
16:51:53, 18 Oct. ( 2767.920000) Lease for IP 192.168.1.69 issued for host Aidan-​J (MAC 64:e6:82:e8:a1:ac). Lease duration: 1440 min
16:51:53, 18 Oct. ( 2767.920000) Device connected: Hostname: Aidan-​J IP: 192.168.1.69 MAC: 64:e6:82:e8:a1:ac Lease time: 1440 min. Link rate: 26.0 Mbps
16:51:53, 18 Oct. ( 2767.850000) Lease requested
bobminors
Re: Hub One and DVR
Well, there's no mention of an ethernet-connected device. You seem to have four WiFi-connected devices on 64, 65, 68 and 69 but that's it.
Assuming you've done the trivial things like trying to plug the DVR into a different ethernet port, I think I would suggest doing a factory reset of the router (paperclip in the pinhole in the back, wait for the lights to stop changing). It will lose any settings you have put in (passwords and so on), but you can save the configuration before you do it if you look under Advanced settings / System / Backup/Restore.
