Hub One VPN issues
Starb7
Hub One VPN issues
Ok, may be a dumbass question but what is this setting for on the Hub One router:
Advanced Settings > VPN
I know what a VPN is and actually use one but I am at a loss as to what to configure/setup in this menu option.  Anyone got any ideas?
Cheers
5 REPLIES 5
Starb7
Re: Hub One VPN issues
No ideas anyone, not even PlusNet?
Browni
Aspiring Hero
Fixes: 59
Doesn't the built in help on the Hub One describe what this does?
Starb7
No, that's why I am asking on the forum.  Also, PN Tech (hmm) haven't got a clue either 😕
Browni
Aspiring Hero
Fixes: 59
I remember seeing a brief description of what it did somewhere but I thought it was in the built in help.
Starb7
Yep, that's all you get.  So, what Port does it use (presumably 1723) how do your Forward the 'VPN' to a nominated device (presumably via Firewall) are there any other setting we should be a aware of?
I ask because I have a VPN inbound on Windows 10 (that did work with my TP Link) that doesn't with the H1... 😕
TIA
Paul
