Hub One VPN issues
- My Router
- Re: Hub One VPN issues
Hub One VPN issues
04-12-2017 4:04 PM
Ok, may be a dumbass question but what is this setting for on the Hub One router:
Advanced Settings > VPN
I know what a VPN is and actually use one but I am at a loss as to what to configure/setup in this menu option. Anyone got any ideas?
Cheers
08-12-2017 11:47 AM
No ideas anyone, not even PlusNet?
08-12-2017 12:15 PM
08-12-2017 1:58 PM
No, that's why I am asking on the forum. Also, PN Tech (hmm) haven't got a clue either 😕
08-12-2017 2:12 PM
I remember seeing a brief description of what it did somewhere but I thought it was in the built in help.
08-12-2017 3:10 PM
Yep, that's all you get. So, what Port does it use (presumably 1723) how do your Forward the 'VPN' to a nominated device (presumably via Firewall) are there any other setting we should be a aware of?
I ask because I have a VPN inbound on Windows 10 (that did work with my TP Link) that doesn't with the H1... 😕
TIA
Paul
