Hub One Router Not Working Properly
GJF
Hello All,
I was recently given a hub one router by Plusnet because my previous router (2704n stopped working). I have a number of applications like Sonos and Steinel Cam that use my router to work. With my old router they worked straight away. With the hub one they no longer and I don't know why.  I have been to the advanced settings on my router, the firewall and configuration and disabled the firewall so it says "Allows all traffic to pass through the Firewall." This has made no difference though as I still can't get these applications to work. Can anyone give me any help or suggestions as to what I can do now? Thanks in advance for any help you can give.
Kind Regards
Greg
Moderators Note: All caps title changed as per Forum rules
11 REPLIES 11
Shep41
Seasoned Pro
Fixes: 6
Re: HUB ONE ROUTER NOT WORKING PROPERLY
You could always change the ssid (wireless network name) on the hub one to the same as the old router, that way you wouldn't have to reconfigure all you connect wireless devices.
Let us know how you get on.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
GJF
Thanks for your help Shep41. I have already deleted my old profiles on the applications and tried the new router so don't think I can do that. Are there any other ideas or things I can do or suggestions? Thanks.
Mustrum
Fixes: 77
The Hub 1 uses the 2.4 and 5Ghz wireless bands, which some devices struggle with. In the advanced WiFi section in the router and untick the sync with 5Ghz band, and add a 5 to the 5Ghz SSID so you can see which band you are connecting to.
GJF
Thanks Mustrum. I have done that and tried both the 2.4ghz and 5ghz with the applications and either works with them.
Any other ideas would be much appreciated. Thanks.
Fixes: 419
@GJF
Can you connect and use other wireless devices?
GJF
Hi Baldrick1, thanks for the reply. I have my smart tv and other devices like my iPad and laptop connected yes. What are you thinking? Thanks in advance.
Kind Reards
Greg
Fixes: 419
It was my polite way of asking/checking if you were using the correct password for your wireless devices.
Fixes: 419
@GJF
Another thought.
Have you tried a factory reset on the devices which will not connect and starting again setting them up from scratch?
Mustrum
Fixes: 77
I suggest resetting your router to standard settings before you get hacked and follow the instructions for setting up your Sonos to a new WiFi network.
https://www.smarthomesounds.co.uk/blog/faqs/how-to-reconnect-your-sonos-system-to-a-new-router-or-wi...
GJF
Yeap I tried that a couple of days ago with no luck. Any other ideas? Thanks.
