Hub One Frequent Restarts
- My Router
- Re: Hub One Frequent Restarts
03-07-2018 11:53 PM
This isn't exactly a problem, but I'm curious to know what's going on.
A couple of months ago, my speeds dropped drastically (I'm on Unlimited Fibre Extra). Plusnet called out a nice Openreach engineer who replaced several metres of cable up to my master socket.
Since then, I've been getting fantastic speeds, well over 70Mb, and I'm very pleased.
However... since then, the hub has been restarting almost daily (or, at least, the 'DSL Uptime' figure in Troubleshooting seldom shows more than a day's uptime). Previously, I was seeing several day's uptime.
This hasn't affected the speed, and the restarts have generally happened when I'm not online - but does anyone have any idea why they're occurring?
The Event Log entries for the last few restarts all look the same, e.g.:
05:25:24, 30 Jun. (3185930.660000) CWMP: session completed successfully
05:25:23, 30 Jun. (3185930.500000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
05:25:17, 30 Jun. (3185923.820000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
05:25:17, 30 Jun. (3185923.810000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
05:25:15, 30 Jun. (3185922.080000) WAN operating mode is VDSL
05:25:15, 30 Jun. (3185922.080000) Last WAN operating mode was VDSL
05:25:14, 30 Jun. (3185920.880000) PPP IPCP Receive Configuration ACK
05:25:14, 30 Jun. (3185920.870000) PPP IPCP Send Configuration Request
05:25:14, 30 Jun. (3185920.860000) PPP IPCP Receive Configuration NAK
05:25:14, 30 Jun. (3185920.860000) PPP IPCP Send Configuration ACK
05:25:14, 30 Jun. (3185920.860000) PPP IPCP Receive Configuration Request
05:25:14, 30 Jun. (3185920.860000) PPP IPCP Send Configuration Request
05:25:13, 30 Jun. (3185919.840000) PPPoE is up - Down Rate=79903Kbps, Up Rate=19978Kbps; SNR Margin Down=3.6dB, Up=7.8dB
05:25:13, 30 Jun. (3185919.820000) CHAP authentication successful
05:25:13, 30 Jun. (3185919.760000) CHAP Receive Challenge
05:25:13, 30 Jun. (3185919.760000) Starting CHAP authentication with peer
05:25:13, 30 Jun. (3185919.760000) PPP LCP Receive Configuration ACK
05:25:13, 30 Jun. (3185919.750000) PPP LCP Send Configuration Request
05:25:13, 30 Jun. (3185919.750000) PPP LCP Receive Configuration Reject
05:25:13, 30 Jun. (3185919.750000) PPP LCP Send Configuration ACK
05:25:13, 30 Jun. (3185919.750000) PPP LCP Receive Configuration Request
05:24:28, 30 Jun. (3185874.980000) CWMP: session closed due to error: Could not resolve host
05:24:26, 30 Jun. (3185872.920000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
05:24:26, 30 Jun. (3185872.910000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
05:24:23, 30 Jun. (3185870.300000) PTM over DSL is up
05:23:55, 30 Jun. (3185841.840000) CWMP: session closed due to error: Could not resolve host
05:23:55, 30 Jun. (3185841.810000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
05:23:55, 30 Jun. (3185841.810000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
05:23:54, 30 Jun. (3185841.420000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
05:23:53, 30 Jun. (3185839.710000) PTM over DSL is down after 1288 minutes uptime
05:23:53, 30 Jun. (3185839.710000) PPPoE is down after 1287 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
05:23:50, 30 Jun. (3185837.070000) PPP LCP Send Termination Request [User request]
04-07-2018 12:23 PM
Hi There, I have looked at your connection history for your account which is shown below:
As you can see the connection does seem to be dropping over night and this ties in with what you advised. Testing your connection we are not finding anything indicative on the external connection of an issue. You have advised the router is restarting over and over, have you noticed if the router is losing power at all or is it just a colour change on router light?
it may also be worth ruling out anything internal at the property that maybe causing the issue. Can you run through our troubleshooting guides here, let us know how you get on:
04-07-2018 11:21 PM
Thanks for taking a look. Unfortunately, I've never been at the hub when it's restarted - I only know about it from the hub's 'Troubleshooting' page.
The hub is plugged into the master socket, which has an NTE5c faceplate - so, while there is an extension, it shouldn't affect the hub. And, as the problem only occurs every day or so (as I write, it's actually been up since around 17:40 yesterday), I can't very well leave the hub plugged into the test socket to see if it still happens!
As I said, whatever is going on, it hasn't affected the speeds, which remain excellent, and, so far, it's only dropped when the connection is not being used. It's really just a minor annoyance, but it would be nice to get to the bottom of it.
05-07-2018 9:47 AM
@calopez In my opinion, there's nothing wrong with using the test socket as that's the best place for the broadband signal since this socket will bypass all internal wiring. If you're still experiencing disconnections the next step would likely be to arrange another engineer for further investigation.
05-07-2018 12:04 PM
Yes, but if I plug the hub into the test socket, I wouldn't be able to use any of the landline phones in the house! And, because the restarts only happen once a day or so, I'd have to leave it like that for an extended period to see if it made any difference. It's just not practical.
I was hoping that the event log entries that I posted would offer some clues to an experienced eye as to what the problem is. However, so long as my speeds remain high and stable, which they have ever since the engineer put in the new piece of cable, I am puzzled rather than concerned!
05-07-2018 12:17 PM
06-07-2018 12:03 AM
Thanks for the suggestion, but I can't do without the extension, either, as four cordless phones in different parts of the house run off it. And if I plugged those into the microfilter as well, surely that would leave me in a very similar position to where I am now - the only difference being that it would be the microfilter splitting the signals and not the faceplate.
Anyway, the hub has been up for over two days now, which is encouraging. A bit of googling found this thread, and others, with very similar problems. The consensus seems to be that it's a 'feature' of the Hub One and the BT HH5 (which, as I understand it, are identical), but no soultions, apart from a third party router. That's a bit drastic for me as I can't say I've been inconvenienced by the issue! It also helps to know it's not just me
06-07-2018 7:32 AM
I'll look at pushing a firmware update to your device when I get to the office and we'll see how that goes.
06-07-2018 12:15 PM
Ah, thanks - that sounds plausible.
When I get home this evening I'll check to see if the firmware has been updated.
06-07-2018 4:16 PM
@calopez, you should now find you're running version 4.7.5.1.83.8.259. let me know how it goes...
06-07-2018 7:08 PM
Bob,
Thanks - I can see the hub's been running the new firmware for just over an hour.
The data rate has also gone up, by one whole point, from 79903 to 79904, so that's a good start
Anyway, I'll keep an eye on it over the next few days.
Thanks again!
13-07-2018 10:22 PM
Just an update: the hub restarted itself three times over last weekend, but now it's been up for nearly six days. Speed has dropped a little (data rate is now 76344), but I'm still getting over 70Mbps, so no complaints there.
All in all,it's looking promising, but I'll continue to monitor the situation.
14-07-2018 11:06 AM
- My Router
