Hub One Firmware
Archer
Hub One Firmware
I know this subject comes up quite regularly but I have not found an upto date response, so please bear with me.
I note my PN Hub One last updated on 9/3/19 to build 4.7.5.1.83.8.263.
Should i worry about getting this updated and if so how please?
Everything seems to work ok, but just thinking about security.
Thanks.
2 REPLIES 2
Fixes: 480
Re: Hub One Firmware
@Archer
This topic is kept up to date. https://community.plus.net/t5/My-Router/PN-Hub-Latest-Firmware-Versions/td-p/1864745
As you can see, your firmware is out of date. Hopefully a Plusnet staffer will come along and trigger an update for you.
MatthewWheeler
Fixes: 503
Morning @Archer
I'm sorry to hear your router hasn't been updated for a while.
Looking at your account I can't see a Hub One on there which will be why it's not been updated as it won't be live on our router management platform.
Can you send me a PM with a photo of the bottom of the router showing the serial number?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
