Hub One Firmware
FIXED- Subscribe to RSS Feed
- My Router
- Hub One Firmware
08-02-2019 3:28 PM
i have 2 pluss net hub ones im using as access points around my pub both havent had firmware updates for a long time is there anyway someone can give them both a firmware uldate
Fixed! Go to the fix.
08-02-2019 4:18 PM
Hi @ken170267,
I've checked your account and your services haven't gone live yet, so we wouldn't be able to push through a firmware update to your hubs at the moment I'm afraid.
Our products team are currently in the process of rolling out firmware updates to all customers and this will conclude by the second week of March. Please let us know if your routers are not on firmware version 4.7.5.1.83.8.263 after this time as we can then ask our products team to push the firmware update to you.
Re: Hub One Firmware
08-02-2019 9:28 PM
hiya im having simular problems my software version is..
4.7.5.1.83.8.237.2.2 last updated 25/10/17
09-02-2019 9:34 AM
Hi @matteastick75,
I've picked up your other post and I'll be back in touch shortly once I've looked into this.
10-02-2019 8:47 PM
@matteastick75, as mentioned in the other thread, your router has been upgraded.
03-03-2019 12:06 PM
hiya all my services are live now any chance of having my firmware upgrade for my 2 old routers
03-03-2019 12:32 PM
If these are not connected directly to 2 separate phone/BB lines, then I can't see how they can be updated.
It does sound like you have used these connected to a 'primary' router to extend the wifi (and ethernet) around your pub.
03-03-2019 12:35 PM
i have yes, i have my main plusnet business hub that i received a few days ago then i have 2 more hub ones that are being used as access points via ethernet cable
03-03-2019 1:09 PM
Thanks for clarifying, I really can't see how PN can update them then
(even if you were to put each of them onto the line at a time, they could be reluctant to send the firmware to them)
I've been running BT Home hubs for years in the same manner as you, right from the HH2 up to HH5. The PNH1 is the same as a BTHH5 internally.
03-03-2019 6:05 PM
Hi @ken170267
Just to clarify - we'd need these routers connected directly to the main landline of the property and they'd need to be updated manually via our Products team - please let us know if/when you swap these over so that we can arrange for this to happen.
Best wishes
Dave
