Hub One Firmware Updates
david12344321
Re: Hub One Firmware Updates
my 4 chromecast audios and 4 chromecast 2's are now playing nice with my plusnet hub one router. a whole week of trouble shooting, no internet (had to use old netgear router to get a connection) and head scratching are over.
google please please dont change preview firmware 1.22.77272 again.
if it's not broke don't fix it lol
i hope bt home hub 5 owners are up and running as well 🙂
jackhouse
Hi - I have a Hub One since I upgraded to fibre a while back. I've had nothing but problems. Current position is my pc will connect but any other devices don't connect reliably. Even my TV which connects via lan and worked fine pre upgrade will no longer connect.
I've raised a few calls with plusnet support but got nowhere - have tried suggested fixes eg changing channel etc.
I've seen that a firmware upgrade has fixed similar issues - could this be a solution? Really need some help...
TerryJC
Have a look at this post: https://community.plus.net/t5/My-Router/Hub-One-Firmware-Updates/m-p/1336992#M313 and check to see when the last update has been done.
Unfortunately, we, (the users) don't seem to be able to apply firmware updates directly, but they are being done.  I checked about a week ago and there had been an update applied in September.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Learnedb
Well, I've had a hub one since I joined in November 2015 and the firmware shows a date in 2009.  Since I have my router dropping the internet connection when I try to upload files to my company's server, I'm trying to explore all possible fixes.
marksandler
I've been sent here by an online chat agent.  My Hub One fiber router is disconnecting momentarily when trying to upload files to the cloud (in this case an 84mb mp3 file).  He said that the firmware needs updating.  Please advise me as to how I go about this please.
Thank you
Mark
Fixes: 1,599
Hi Mark, I am sorry to hear you're having problems with your broadband.
This is something that we're aware of, more information can be found here: https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
I hope this helps.
marksandler
Thanks for the reply....I don't think I'm any the wiser other than there's a fix on the way?  In the interim, is there a temporary fix that could be applied to my hub and if so, how would I go about receiving it?
Thanks again
Mark
Mustrum
Fixes: 76
@marksandler If you go to the thread that @Gandalf highlighted, and ask bobpollen to make the change to your router.
marksandler
Thanks @Mustrum Smiley
familysimms
Please can you update our router, the connection keeps dropping and I been told by your customer service that you need to push the new software to my router.  I work from home and it is becoming very difficult to work, so I would appreciate it if this could be done as soon as possible.
Many thanks,
Chris
Legend
Fixes: 169
I've requested that's done for you and the update should be pushed to your router in the next 72 hours.
marksandler
Hello Chris,
I wonder if you can help me too please?  Supposedly a firmware update was sent to my fiber router some months ago, and although the unit isn't dropping out as often when uploading audio files to Google Drive (D/L is fine), it's still dropping out on occasion and takes a couple of attempts before the file has been successfully sent.  Any chance of pushing the upgrade again or any other solution you have to offer please?
Mark
Chris
Legend
Fixes: 169
Hi Mark, if the connection isn't dropping on uploads but is just dropping randomly this sounds more like a line fault. I'd advise getting a new thread open for support on this as it sounds unrelated to the rest of this thread.
bobpullen
Fixes: 315
@familysimms, I've pushed a firmware update to your device that should have fixed the problem.
@marksandler, It looks like an attempt was made to push an config change to your router back in May but it failed because there was an issue trying to communicate with your router. I'm having the same problems now trying to push the firmware update to you. I assume the router is powered up and you're currently online?
marksandler
Hi Chris,
The connection is only dropping out when uploading. I'm usually only successful in completing a full upload once in every 5 or 6 times of trying without the connection dropping and the hub changing to orange status. Downloading is fine.
Mark.
