Hub One Firmware Update?
stevemc
I've not been using my Plusnet Hub One for a while (a number of years!) but it's recently (last week or so) been plugged in after the death of a third-party modem/router and is being used again.
It is currently using the following firmware:
Plusnet Hub One | Software version 4.7.5.1.83.8.226 | Last updated 12/01/17
I'd like to get a firmware update pushed to it so that it is up to date. How can I ensure that this happens?
Cheers
Steve
46 REPLIES 46
Fixes: 390
Re: Hub One Firmware Update?
@stevemc Unless the hardware guru @bobpullen  see this, you have no chance - that Hub will have fallen off the hardware maintenance platform a long while ago, and its current software version cannot be auto-updated, anyway.
Fixes: 480
@stevemc Welcome to the forum.
I've a feeling that hubs with firmware that old are no longer supported by the automatic update platform. You need a Plusnet staffer to come along and advise whether it needs replacing.
@jab1 types quicker than me!
bobpullen
Fixes: 331
@stevemc - the guys are right, no way to update a device running a version that old. The certificates used for remote management have changed since your hub was manufactured.
I can arrange for a replacement to be shipped if you like?
stevemc
Bob et al,
Thank you for your kind replies.
@bobpullen Yes, I would like to take up the offer of a replacement. Can you ascertain my details or do I need to message you separately?
Thank you all; much appreciated.
bobpullen
Fixes: 331
@stevemc - I've ordered a replacement hub for you. It will be dispatched tomorrow and likely arrive with you on Tuesday.
stevemc
@jab1 , @Baldrick1 & @bobpullen ,
Thank you all for your advice and practical help. Much appreciated.
This was my first foray into the Community and it has been a pleasant, supportive and effective place to have asked my question.
j-t
Hi Bob,
Like Steve, I've also not been using my Plusnet Hub One for a similar number of years for the same reason, but keep it in case it's required by Plusnet to diagnose a line problem if required.
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 14/08/17
Would you be able to arrange for the router to be replaced, please?
Cheers
Tony
bobpullen
Fixes: 331
@j-t - are you using it/planning on using it? If not, then I'd rather we weren't sending another unit out for it to sit in a cupboard somewhere Wink
j-t
@bobpullen
That's a very fair point.
However, I do wonder how Plusnet would support me if there was a suspected line fault and I was using a third-party router.
As this is now off-topic, where is the best place to have this discussion?
Cjeers,
    Tony
peteradie
I am also running old firmware on hub one.
Currently, the router has:
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated Unknown
4. Board version: Plusnet Hub One
Can anyone help?
Cheers,
Peter
Fixes: 390
@peteradie I suspect that your Hub has 'fallen off' the management platform. Has it always been connected and powered up? I don't think a Hub running such old f/w can be updated, though.
peteradie
Thanks @jab1 for the prompt reply. Much appreciated.
As far as I know the router has always been plugged in and powered on.
If the firmware can't be upgraded, can the router be replaced?
I'd prefer to run with a fully patched router, for obvious reasons.
Cheers,
Peter
Cheers,
Peter
Fixes: 390
@peteradie If it has always been powered up and plugged in, it has fallen off the management platform - a long time ago.
I'll tag @bobpullen (the Tech guru on here), and hope he picks this up next time he visits - he's the man for this.
peteradie
@jab1 Thanks John. Much appreciated.
I only noticed this by accident when I was browsing the forums earlier and saw the pinned post about firmware updates here.
https://community.plus.net/t5/My-Router/PN-Hub-Latest-Firmware-Versions/td-p/1864745
Cheers,
Peter
