Hub One Firmware Update Request
battyma
Hub One using Software version 4.7.5.1.83.8.263. Having DNS issue. Could you please push out update?
1 REPLY 1
bobpullen
Fixes: 331
Re: Hub One Firmware Update Request
I've made some changes this side. Try a factory reset by inserting something into the pinhole at the rear of the device until the status LED flashes green.
Give it a few days and you should have the latest firmware. If not, let me know.
