Hub One Event log
FIXED- Subscribe to RSS Feed
- My Router
- Hub One Event log
14-06-2021 10:34 AM
Just looking at the event log on my newly set up Hub One (10th June).
Appears (to me anyway) to be a 4th hand router because there were admin log ins in July (2019:?) ,April (2020?), November (2020?) and then me in June 2021! Is it normal for a router to be returned /reused this many times
Presumably chances are not high of it lasting too long if it really has been used, on and off, for two years !!
Fixed! Go to the fix.
Re: Hub One Event log
14-06-2021 11:31 AM
It is more likely that the same user logged in 4 times. Thse devices should last much longer than 2 years, is free and comes with a 12 month guarantee.
I am however surprised that it hasn't been fully reset.
14-06-2021 2:12 PM
Thanks for getting in touch @davidj66. I'm sorry to hear it sounds like the router you received doesn't sound like it's been fully wiped and only done partially so. I can confirm that we do refurbish, wipe and reuse some routers that are returned to us. The router logs you're seeing however shouldn't impact the speeds or performance of the router. As @Baldrick1 pointed out our routers come with a 12 month warranty.
Should you have any issues with the router then please do let us know.
