Hub One Connections not shown
ldhopl
Interested
I am using :
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 26/02/19
and although the router Home screen shows all ethernet connections , under Advanced Settings some of these connections are not shown or may be shown with a ‘Not Connected’ attribution . These ethernet Devices are all given Static assignments in the 192.168.1.65 – 192.168.1.83 (Always use this address : Yes) . I see an earlier issue seemed to raise this subject ,
Hub One not showing all connected devices” and BobPullen (Admin) replied saying it would be fixed . Unfortunately the suggestion workaround in reply 34 does not work for me . Is there progress on a router update ?
