Hub One Additional Hardwired Ports
- My Router
- Hub One Additional Hardwired Ports
29-11-2018 1:57 PM
HI
I need to go beyond the 4 ports on the Plusnet Hub One router so was looking at adding a basic switch to it. Any recommendations or should I look at changing the router itself?
I just need a coupe of extra ports for home hubs for lights etc. which have to have a wired connection so thought something like a TP-Link 5 port or 8 port would do the job without costing a lot.
I'm guessing a more port heavy option from Plusnet is not going to happen.
Message 1 of 2
(505 Views)
1 REPLY 1
Re: Hub One Additional Hardwired Ports
29-11-2018 2:10 PM
i have several switches plugged into my hub one, tp link one should be fine
Message 2 of 2
(495 Views)
- My Router
