Hub One - 5GHz WiFi issue
MortimerCat
Re: Hub One - 5GHz WiFi issue
Thanks for attempting to update me 🤓    As my IT needs are a bit more specialised than most, the Plusnet supplied router did not have all the features I needed. I ended up using my own equipment anyway.  Service has been great since then 👍
Mitchjc123
Welcome back @bobpullen and thanks again for your work. Please could you send any latest updates our way as we've been having more issues over the past few weeks of the grinding to a halt variety.
bobpullen
Fixes: 330
@Mitchjc123 - done.
Usual applies, you'll need to give the hub a quick restart to apply.
Mitchjc123
You’re the best @bobpullen - have restarted and will keep an eye on things. Fingers crossed!!
P.S. I hope Plusnet are giving you a huge raise after all this
GeoJ1
@bobpullen Please can you update my Hub One router? It seems to have dropped off the maintenance list.
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated Unknown
Thanks!
Eva01
Hi @bobpullen,
+081441+NQ50527901
bobpullen
Fixes: 330
@Eva01 - update pushed. You'll need to restart your hub to apply it.
@GeoJ1 - I've replied to your private message.
jasonanthem
Hi, I'm having the same issue (5GHz). I've had a notification that the new firmware was to be installed. I followed the instructions and nothing happened. It's still showing:
3. Firmware version: Software version 4.7.5.1.83.8.263 Last updated Unknown
I've reset the router now so it's all back to factory standard. Happy to send a PM with serial number, etc if that's what's needed to push the update again. I can confirm there is no evidence in the log files of the firmware update being downloaded or applied.
andypea
I've been having 5Ghz wifi drop outs for a long time and just found this post says that there is a fix available.
I'm on firmware 4.7.5.1.83.8.263 (last updated 25/03/19) and Hub serial number is +081441+NQ65004966.
Is it possible to have the latest firmware installed?
many thanks
bobpullen
Fixes: 330
@jasonanthem - done. You'll need to restart your hub to apply the update.
@andypea - for some reason, your hub has dropped off the management platform. If you can factory reset it by inserting something into the pinhole at the rear of the device until the status light flashes green then I'll give things another go.
andypea
Jason,
Hi, I've done the factory reset as requested
bobpullen
Fixes: 330
@andypea thanks, all done. You'll need to switch your hub off/back on to apply the update.
andypea
New firmware installed ok. Many thanks for your help with this.
regards
Andy
t-c
Hi @bobpullen
Router doesn't appear to get auto-updated, serial number: +081441+NQ41574743
Thanks!
0llie
Hi again @bobpullen
For the past few weeks I’ve been experiencing issues again.
Router grinds to a halt, devices not connecting to 5ghz and having issues with my HomeKit setup. Both my HomePods are constantly dropping from the 5ghz network which is causing a lot of headache. I’m at my wits end with this router.
The router is currently on the 289 firmware.
Please can you push the latest 289.1.3 firmware to my router.
Also are there any plans for a new router any time soon? The current problematic rebranded BT Home Hub 5 is rather old now.
Thanks.
