Hub One - 10.x.x.x network
- My Router
- Re: Hub One - 10.x.x.x network
21-12-2018 7:06 PM
Can a Plusnet Hub One be configured to use a 10.x.x.x home network or must it use a 192.168.x.x network?
Message 1 of 3
(1,146 Views)
2 REPLIES 2
21-12-2018 7:07 PM
it can't use the 10. range as iirc BT wifi uses that range and the HubOne is a re-badged home hub 5
26-12-2018 3:08 PM
This could lead you to a low cost solution. https://community.plus.net/t5/My-Router/Will-Plusnet-supply-an-alternative-to-the-Hub-One-for-FTTC/m...
Message 3 of 3
(1,044 Views)
- My Router
