Hub Magement access from Internet
leaky5
Is there a port you can connect to on the One hub so it can be managed from the Internet ?
5 REPLIES 5
Fixes: 480
Re: Hub Magement access from Internet
@leaky5
I’m afraid not. I believe that Plusnet can trigger a reset through their system.
leaky5
@Baldrick1 Thanks. I have a remote site with one and ideally remote access would have been good
Fixes: 585
@leaky5  use VPN access to the remote site and then connect to the hub from the local network
leaky5
@MisterW Thanks, but we only have one fairly dumb out of band magagement device on the LAN
Fixes: 585
@leaky5  in that case I suggest you consider getting a new modem router that supports remote management and a VPN server so that you can connect to the remote site.
