Hub 2 high ping
ukguy1
Hub 2 high ping
Hi, since we recontracted last month and received the Hub 2 we've had many more problems.
The hub 2 keeps lagging on the Mac with high pings of up to 1000. We never had these issues with the Hub 1.
The sync speed of the fibre is ok but it seems to be the router. We have a similar router at another address and that seems fine.
It's just strange how this coincides with signing another 18 month contract and just adds to the stress of being prevented from upgrading to full fibre (because of no phone line option)
Anyone else had this problem?
3 REPLIES 3
Fixes: 1,495
Re: Hub 2 high ping
Never noticed anything like with the Hub 2 on my macs.
ukguy1
Re: Hub 2 high ping
Ok, thanks. It does it sometimes on the phone too.
A reboot usually sorts it for abit, hardly ever had to reboot the hub 1
Fixes: 1,664
Re: Hub 2 high ping
Is your Mac wired into your Hub 2 using an ethernet cable or connecting wirelessly when you're seeing a high ping?
