Hub 2 - flushdns needed on restart every time
- My Router
- Hub 2 - flushdns needed on restart every time
06-05-2024 7:57 AM
Since getting full fibre I've been having issues with a slow and unstable connection, both on my current PC and my old one. After some googling possible issues I found it could be fixed by running the ipconfig /flushdns, /registerdns, /release, /renew commands in Command Prompt. This was great, and I thought had resolved all my issues until I found out I have to do this every time the computer is either powered off or enters sleep mode.
If it was just the one PC I'd assume the problem was with that, but since it's happening on both computers I'm wondering if there's something in the router settings I need to change?
I'm on a Plusnet Hub 2, and both computers are running Windows 10.
- My Router
