Hub 2 Upgrade but need more LAN Ports
Richchad
I am just considering renewing my FTTC Plusnet contract so thought perhaps I should also upgrade from Hub 1 to Hub 2, however reading other posts I understand there are only 2 LAN Ports, at present I am using all 4 LAN Ports on my Hub 1.
If I do upgrade to Hub 2 is there a problem with adding something like a 4 or 7 port LAN Extension?
Anyone doing this and what extender are they using?
Thanks in advance.
6 REPLIES 6
Fixes: 1,495
Re: Hub 2 Upgrade but need more LAN Ports
There are 3 available LAN ports on the Hub 2.
You'll need to get an ethernet switch to connect to the hub 2.
I have multiple switches in my setup and it works fine. I have some of these https://www.amazon.co.uk/gp/product/B07HP6ZLSM
But any gigabit switch should be fine
Fixes: 392
@Richchad There are three LAN ports - all you need to do is purchase switch to extend the available number.
Plenty on, for instance https://www.amazon.co.uk/s?k=network+switch&crid=3EI3T0N89QDKT&sprefix=netwo%2Caps%2C97&ref=nb_sb_ss...
Richchad
@jab1 @dvorak  Thanks for the info and links to switches, just what I needed.
@Richchad
Just make sure that any ethernet switch you buy is spec'd as 10/100/1000.
Some cheaper ones are only 10/100, so will introduce a bottleneck on your network.
bill888
Champion
Fixes: 40
fwiw, I posted some info on variety of switches a few weeks ago:
https://community.plus.net/t5/My-Router/Plusnet-Hub-2-and-TP-Link/m-p/1926476#M35570
BrizzleRocker
Have a search through these forums and you’ll find links to a USB powered one that just plugs into the back of the Hub, no need for external power.
