Hub 2 - 2 IP addresses ? 192.168.1.254 and 192.168.1.236 ?
FIXEDTopic Options
- My Router
- Re: Hub 2 - 2 IP addresses ? 192.168.1.254 and 192...
- « Previous
- 1
- 2
- Next »
26-03-2025 2:42 PM
It’s my wife’s IPad !!! I blocked it to see what would happen and then narrowed it down to her device - surprised the hub manager doesn’t identify as iPad - maybe as it’s old !
Anyway - thanks for help Dan.
Re: Hub 2 - 2 IP addresses ? 192.168.1.254 and 192.168.1.236 ?
26-03-2025 5:01 PM
Hi, glad you managed to get thus fixed, I am also new to plusnet... so far so good... can I just ask are you using the router they sent you? I'm using my own one, rather than the one they sent
Message 17 of 21
(844 Views)
26-03-2025 5:38 PM
Hi Ryan - I use the hub2 that Plusnet sent me.
Very stable and never had any problems.
Message 18 of 21
(830 Views)
26-03-2025 5:48 PM
They are ok, I went for the TP Link BE9300 it's 2.5gb one and I run it with a 10gb network server.. helps with my work at home...
Yes the plusnet one is the same as the BT home hub 2 only white... I had so many issues with it at first that's why I bought my own 👍
Message 19 of 21
(820 Views)
26-03-2025 5:51 PM
The hub manager interface is not that good but luckily don’t need to fiddle with it much.
Message 20 of 21
(818 Views)
26-03-2025 6:19 PM
Agreed.... it's not very user friendly. Not much to play with
Message 21 of 21
(805 Views)
- « Previous
- 1
- 2
- Next »
- My Router
