Hub 1 wifi range
- My Router
- Re: Hub 1 wifi range
Hub 1 wifi range
26-04-2021 12:02 PM
New customer, all connected up fine, pleased with speed - BUT - wifi range is awful. It's much worse than previous provider's router, even though that was many years old.
My Roku TV stick is in a straight line with the router, you can actually see one from the other when the door's open, they're only 5 meters apart, yet it reports weak or no signal and I've had to balance it on a pile of books to get it to work (intermittently).
What's the solution? Are there any tweaks to the router settings that might help? Or I'm I going to have to fork out for a better router. Thanks.
26-04-2021 12:05 PM
Moderators Note
This topic has been moved from Fibre to My Router
26-04-2021 12:16 PM
@beaglebus Welcome to the forum.
Try separating the 2.4 and 5 GHz bands, see. https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Try each band in turn and use the best.
If that fails then try changing the channels by going into the wireless settings and changing the settings from auto then trying different ones. If you get a sniffer app, I use WiFi analyser on an Android phone, you can see which bands are least busy.
If you want a better hub with superior WiFi for very little money then get a BT Smarthub 6 from an auction site. Settings are here https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601, many of us use them.
26-04-2021 2:23 PM
Thank you. I've ordered a BT Smarthub 6 as suggested. I see what you mean about this being commonplace with disgruntled Hub 1 users.
02-05-2021 1:56 PM
My BT hub arrived yesterday, I followed your instructions carefully - and it all worked perfectly. Thanks so much for your help, I wouldn't have worked it out on my own - so I'd just add that if anyone else is struggling with the weak wifi from their PlusNet router, get one of these - it sorted out my problems with very little fuss. And as a bonus, I no longer have that horrible bright blue 1000 watt led strip to annoy me
