Hp printer won’t connect to router
- My Router
- Re: Hp printer won’t connect to router
05-01-2021 5:29 PM
05-01-2021 5:38 PM
@Zoena Welcome to the forums. Most modern wi-fi enabled routers have to be connected via set-up procedure detailed in their user manuals - have you checked what it says? I've never had an HP printer, so can't help further I'm afraid.
05-01-2021 6:26 PM
05-01-2021 6:33 PM - edited 05-01-2021 6:34 PM
I'll try and help - but no guarantees. Exactly which printer is it?
05-01-2021 6:37 PM - edited 05-01-2021 6:48 PM
Welcome to the Forum Zoena
Have you downloaded the HP printer Software for your new printer onto your laptop ?
https://support.hp.com/gb-en/printer-setup
HD
05-01-2021 8:30 PM
Try deselecting the 5GHz on your router and let printer connect using 2.4GHz or visa versa. When connected reinstate the GHz you switched off.
05-01-2021 8:39 PM
05-01-2021 8:40 PM
05-01-2021 8:48 PM - edited 05-01-2021 8:49 PM
Have you got the Printer settings set to connect wirelessly Page 29 of manual.
05-01-2021 8:49 PM - edited 05-01-2021 8:51 PM
@Zoena Have you followed the instruction on P21 &c of the manual?
Crossed with @LifeonMars -who must be looking at a different manual.😀
05-01-2021 9:27 PM
05-01-2021 9:27 PM
05-01-2021 9:31 PM
Did you try with switching one of your GHz off on the router. Try switching 5GHz off as 2.4GHz goes further and try and connect the printer
05-01-2021 9:36 PM
05-01-2021 9:37 PM - edited 05-01-2021 9:44 PM
Change the channels ? and try. Are you entering the correct details passwords etc into the printer settings ? Not using WPS set up ?
- My Router
