Hp printer won’t connect to router
Zoena
Recently joined plusnet m. Bought a brand new hp printer today and it won’t connect to wifi... I have ordered a wire to connect direct to pc in Hopes this helps but am I gonna have to have it plugged into the pc all the time? Or once set up done it will find the wifi? I’ve tried all sorts and it’s just not having it. Never had this problem with sky?! Just plugged the printer in and pretty much off I went?
16 REPLIES 16
Legend
Fixes: 254
Re: Hp printer won’t connect to router
@Zoena Welcome to the forums. Most modern wi-fi enabled routers have to be connected via set-up procedure detailed in their user manuals - have you checked what it says? I've never had an HP printer, so can't help further I'm afraid.
Zoena
User manual is useless lol all it says is if can’t find wifi connect via Ethernet or usb but it didn’t even come with a cable! I have read another user on here never got his hp to connect so slightly worried...
Legend
Fixes: 254
I'll try and help - but no guarantees. Exactly which printer is it?
Welcome to the Forum  Zoena
Have you downloaded the HP printer Software for your new printer onto your laptop ?
https://support.hp.com/gb-en/printer-setup
HD
LifeonMars
Seasoned Pro
Fixes: 12
Try deselecting  the 5GHz on your router and let printer connect using 2.4GHz or visa versa. When connected reinstate the GHz you switched off.
Zoena
Hp 2700 deskjet, and thanks !
Zoena
Yes downloaded the app? On both pc and phone? That’s all user bumph said to do?
LifeonMars
Seasoned Pro
Fixes: 12
Have you got the Printer settings set to connect wirelessly Page 29 of manual.
http://h10032.www1.hp.com/ctg/Manual/c06611085
Legend
Fixes: 254
@Zoena Have you followed the instruction on P21 &c of the manual?
Crossed with @LifeonMars -who must be looking at a different manual.😀
Zoena
I’ve done all that still zilch.. I do use a wifi extender thing from my pc to the router that wouldn’t cause issues would it?
Zoena
How do I deselect that?
LifeonMars
Seasoned Pro
Fixes: 12
Did you try with switching one of your GHz off on the router. Try switching 5GHz off as 2.4GHz goes further and try and connect the printer
Zoena
Yep done that and still nothing ugh
LifeonMars
Seasoned Pro
Fixes: 12
Change the channels ? and try. Are you entering the correct details passwords etc  into the printer settings ?  Not using WPS set up ?
