How to use BT WiFi Disk with plusnet hub 2
DanielB
Happy New Year!
I consider to switch from BT Full Fibre to Plusnet.
How can I use BT WiFi disc that I bought second hand with the plusnet hub 2?
To work both indoors and in the garden seamlessly I need WiFi mesh.
Thank you
2 REPLIES 2
Fixes: 480
Re: How to use BT WiFi Disk with plusnet hub 2
Sorry @DanielB, they are not cmpatible. You can however use a BT Hub with your Plusnet service. You will find configuration instructions pinned at the top of this board.
DanielB
Thank you,
I will follow the instructions at the post pinned to the top of this forum.
https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/td-p/1795292
