How to tell the difference between a Plusnet fibre router and a Plusnet standard router.
shermans
I have been doing some decorating which meant disconnecting the new Plusnet fibre router.  Now I need to re-connect but I still have the original Plusnet cable router, which is not very old.  They both look alike, just different colours.  How can I tell which one is which ?
Stupid boy, Pike !
2 REPLIES 2
Fixes: 48
Re: How to tell the difference between a Plusnet fibre router and a Plusnet standard router.
Have a look at the pictures on the following "setting up....router" page
https://www.plus.net/help/broadband/
shermans
Silly me !  It is perfectly obvious when I look at those photographs !  Anyway, I now realise that the Fibre router is twice the size of the cable router.  So thanks.
I was thinking of doing "trial and error" but was reluctant for fear of screwing up all the settings !  So now I can put it all back together without worrying.
