How to tell the difference between a Plusnet fibre router and a Plusnet standard router.
- My Router
- How to tell the difference between a Plusnet fibre...
10-11-2017 9:23 AM
I have been doing some decorating which meant disconnecting the new Plusnet fibre router. Now I need to re-connect but I still have the original Plusnet cable router, which is not very old. They both look alike, just different colours. How can I tell which one is which ?
Stupid boy, Pike !
Re: How to tell the difference between a Plusnet fibre router and a Plusnet standard router.
10-11-2017 9:59 AM
Have a look at the pictures on the following "setting up....router" page
https://www.plus.net/help/broadband/
10-11-2017 10:51 AM
Silly me ! It is perfectly obvious when I look at those photographs ! Anyway, I now realise that the Fibre router is twice the size of the cable router. So thanks.
I was thinking of doing "trial and error" but was reluctant for fear of screwing up all the settings ! So now I can put it all back together without worrying.
- My Router
