How to setup Remote Management of the PlusNet Hub One Router
- My Router
- Re: How to setup Remote Management of the PlusNet ...
31-03-2017 6:13 PM
I want to setup access to my router from remote location so I can be out the office and log into the router web configuration web page
Re: How to setup Remote Management of the PlusNet Hub One Router
01-04-2017 10:38 AM
The Hub One is a rebranded Home Hub 5 type A. As far as I know, it is not possible to remotely access the web interface from an external IP address.
You could install a VPN server, to access the Hub One.
A much simpler solution is to replace the Hub One with a router which does support remote management.
25-04-2017 1:45 PM
There is a login for remote management on port 4567 though. What does this do? ... and does anyone know what the required username and password are?
- My Router
